caliper paint
wheredwhogo?
IN THE ATX!!!!!!
besides taking the calipers off and powdercoating, had anybody used those caliper paint kits out there. please chime in, thanks
I just cleaned mine real well and put a coat of clear Rustoleum on them. They still look great. And it makes cleaning them easier.
DUPLICOLOR caliper paint kits work great! its thick and flows on nice. (no brush marks) i didn't even take mine off.;)
i used hammerite smooth
easy to put on and looks cool
it has lasted 2 years and looks as good as the day i did them :rock:
Same here,worked excellent!:rock: The kit will do about 3 pairs of calipers also maybe 4:dontknow:
Did all of mine and love the results.
That's what i used! It works great!
I painted mine with Yellow Venom one day, it worked pretty good. Id have them powdercoated if I was to do it again though.
i used Duplicolor but i used the spray can not the bush i just sanded alot ot the rust off cleaned it and painted it
here is a dirty pic ;) (Dirty mean the truck is dirty):D
I used G2's (available from Eastwood) Red on the fronts. Rears will get painted this Spring.
Painted them with the Brush Caliper paint - Great stuff
Got about 1.5 hours curing time.
Jim
Here's pic, not a closeup, but seeable ...
I went the cheap way right before a local show and cleaned mine and sprayed a couple of coats of clearcoat on them.
thanks guys, i was a little concerned that the brush on kits would leave streaks, but you have proven otherwise. thanks for the help.
Where do you get these kits...I am looking at doing this too!:)
Mine came from AutoZone. The brush it came with was pretty weak. After getting two calipers done the brush came apart.. Which made me have to use a tooth brush for the last two. Still, it came out great. No streaks, no brush marks; the paint flows smoothly as it cures.
I'll post up some pics of mine later today. A piece of advice, toss the brush that comes with the kit. They are el' cheapo at its best. Spring for a decent quality brush, 1/2" or 3/4" wide -- it will help get into tight spots. The paint, as it cures, dries flat, no brush strokes. Take your time with prep work, masking and cleaning the calipers (G2's kit included a can of brake cleaner).
