Srt10650
- Joined
- Sep 30, 2016
- Messages
- 450
- Reaction score
- 490
Speed Bleeders are by Russell part number #639590Hey which speed bleeders did you use?
They worked for me, still on my truck today.Thanks for posting those , I had no idea the existed .. has anyone installed them ? Do they really last and work ?
Excellent thanks for the info and part # ..They worked for me, still on my truck today.
How many did you need .. Fronts have 2 bleeders each caliper and rears 1 each … do or did you get 2 bleeders per package ? I saw a review a guy only got 1 per package … I hate reading reviews lolSpeed Bleeders are by Russell part number #639590
Cool, thank you!Speed Bleeders are by Russell part number #639590
Total of 3 packages, 2 per package. 2 for each front caliper and 1 each for the rear calipers.How many did you need .. Fronts have 2 bleeders each caliper and rears 1 each … do or did you get 2 bleeders per package ? I saw a review a guy only got 1 per package … I hate reading reviews lol
@Srt10650
I used the same Russell part number for the front and rear. They’re both the same size.What is the speed bleeder part number for the rear?
EDIT: Never mind, found it:
Dorman, P/N 12601 - speed bleeder - for rear Ram SRT-10
Brakes. 38-24x1.19 (aka 3/8-24 X 1-3/16 In.)
I had bought them for my Black truck and just my Amazon order from a couple years ago.
Speed bleeder for a 2005 QC the Front and Rear are different, they have different size & thread pitch.I used the same Russell part number for the front and rear. They’re both the same size.
Thanks ! Good to know before I order them …Speed bleeder for a 2005 QC the Front and Rear are different, they have different size & thread pitch.
Front (10mm): 4 total needed (2 per front caliper x 2)
Dorman 12706 = 10mm x 1.0, 33mm long
Dorman 12709 = 10mm x 1.0, 35mm long
Russell 639630 = 10mm x 1.0, 33mm long
Russell 639560 = 10mm x 1.0, 35mm long
Speedbleeder.com SB1010 = 10mm x 1.0, 1 inch
Rear (3/8in): 2 total needed (1 per rear caliper x 2)
Dorman 12701 = 3/8-24 x 1 3/16 inch long
Russell 639590 = 3/8-24 x 1.25 inch long
Russell 639600 = 3/8-24 x 1.5 inch long
Speedbleeder.com SB3824 = 3/8-24 x 1.0 inch long
Note 1:
Please note that Speedbleeder.com “original auto chart” has
the two part numbers reversed. You need (4) SB1010 and (2) SB3824
Note 2:
The packaging usually has two bleeder.
Perfect thread pitch is imperative for clean holes!!!Thanks ! Good to know before I order them …
I knew something like that was coming hahahaPerfect nut thread pitch is imperative for clean holes!!!
I used the same Russell part number from both front and rear. Haven’t had any issues.Speed bleeder for a 2005 QC the Front and Rear are different, they have different size & thread pitch.
Note 1:
Note 2:
Looks like they were 2mm differentI’ll find out one way or the other .. I’m going to start with the front first ..
That may make a difference.. f the thread pitch is different but the length shouldn’t be a problem I’m guessingLooks like they were 2mm different
I can't figure it out!Looks like they were 2mm different
I will when I order them hahaha they work or they don’t . I will compare the threads .. definitely don’t want to screw something like the caliper threads up ..I can't figure it out!
