Cam sensor on 2005?
2quik6
Is there a cam sensor on the 2005 SRT10 or only a crank sensor? I can find a crank sensor listed but can't locate a cam sensor. The location of each on the engine would be helpful also.
Thanks
Ok, I found it in the service manual, right above the water pump and under TB. Also have the instructions on replacing it correctly making sure the wheel is at the high side 1 15/32" or less depth from wheel to mounting face.
Yessir. There is a taller face on cam gear. You set up cam sendor up against it. Then tighten. It'll set needed gap when you start engine boss:rock:
