BlackViperRam04
Where is a good place to buy a cam? What kind of cams are out there? What other mods will I need to do when I swap out the cam?
Depends on how big you want to go. The mopar comp coupe cam is an upgrade over stock. Comp Cams, Inc sells a "viper truck" grind that is close to the specs of the mopar comp coupe cam. You can do either one of those without having to mod anything else (except maybe your tune).BlackViperRam04 said:Where is a good place to buy a cam? What kind of cams are out there? What other mods will I need to do when I swap out the cam?
