camaro ?
Houstonsrt10
my 2000 camaro is acting up however i currently have v6 in it i been thinking of putting an ls1 in, is it possible will it fit right in
i dont see why not, you will probably need a different trans, and engine mounts, wiring for the v8 and fuel pump
yea it will fit in - but not worth it with all the used v8 2000 camaros. In addition to different trans, and engine mounts, wiring for the v8 and fuel pump - you probably need a tranny crossmember, heavier springs upfront..its kind of a pita
Not impossible at all!
People do this daily and it's not that big of a deal. Check out LS1tech.com for info. Do a search on v-6/v8 swaps. I have alot of what you'lll need as well. LS1 crossmember, fuel tank and pump, complete fuel line set, quite a few other things I can't think of right now.:confused:
If it helps you i got a boy that knows those cars inside and out if you have any questions
Wanna buy a 98 SS with a Texas Speed Built Forged 370, Full manual 4L80, Yank 3400?... :rock: Save you lots of work :dontknow:
