cams
FaSt-RAM-716
sparkill,NY
im looking to get some cams are they worth getting? if so what are some good cams to run with the motor that has no s/c or turbo? :burnout:
Call Joe @ PBJ. He has some custom grinds and will be able to help you get where you want to be.
Is it worth getting a cam if the motor is not going FI? Was just curious about this myself. IOW is the stock CAM and heads a good setup and are the gains going to be signifigant if they arre replaced with aftermarket?
A huge gain is gotten from a cat delete, about 25 rwhp or in that area, I think some have said with heads, rockers, and cam i think it was in the 50 rwhp area,
Vipertruck9233 did his ang got over 500rwhp from remembrences
So how many different cams are out there for our trucks and what are the specs on them....hydraulic,manual,roller ????? Lift ,duration????
Mine made 535 rwhp and 567 rwtrq. My torque line was almost flat across the sheet.
That was a custom grind cam, custom head porting, throttle body and intake runners port matched to Belanger headers with high flow cats. WOuld have made a little more with no cats. Build was done by PBJ.:rock:
