Can SCT programmer pull only codes from Dodge Ram HEMI?
QuickSilver said:
Might be engine picific.... .i.e. 10-cylinder engine not 8.
Quick
Yea I thought that but didn't know since OBD-II ports look the same. Just thought it will act as a scanner and read the computer?
you should also be able to use the key to check them. believe its on off on off on off on ??? Code will flash on the dash.
on the cummins(im sure all dodge) you hold the "trip reset" button in, then turn the key to run then it goes into a diagnostic mode, and it will siplay codes in the milage area.....really cool to watch
I have a super chips programmer and it pulls codes on my truck and the data monitor mode also works on my truck. So, I would say you could pull codes from a hemi with your SCT
