can we talk injectors?
floridaboy
Jax Fl
I just picked up a set of 48lb injectors from Roe. Can I install them without a retune? Is the computor capable of seeing the differance in size and make adjustments according to air/fuel?
I'm wanting to install these and remove the paxton extra fuel pumps. Saen already tuned it when I removed the split second box and installed the vec3.
He said at that time I was maxing out the injectors and was having to make the differance up with my meth.
By the way I installed the Roe throttle body yesterday. I like the throttle response much more. Only took about an hour from start to finish to install.
If you remove the pump how will make up the flow? You can run 100lbs injectors and still run lean if you do not keep good flow and line pressure.
You cant install larger injectors and reduce the fuel system, if anything you would increase the fuel system.
all larger injectors do is allow more fuel that is supplied by the pump.
And yes with the larger injectors you would need another tune to get the best out of them.
put in simple terms of course, but dont remove any of the pumps
The Roe supercharger set up uses 48lb injectors. This is useing the stock pump only. The main reason I want to remove the pumps is that it's one more part to break. Atleast that is my logic.
I think your right about the tune.
Don't remove any of the pump/s if you want the motor to stay alive.
What an injector will support/flow is dependent on what the fuel system will suport.
You have to have an adiquate supply of fuel to the injector for it to work properly.
Yes with an injector change you will need to retune.
There is one thing that he has going for him. VEC 3. In the VEC software is a setting that allows for adjusting for the size injector. For example: if you are using a injector that is double the stock one, then the pulse for fuel is half the size. That allows the same amount of fuel to be delivered to the engine.
I bet if you contact Sean, he can alter your VEC tune based on just changing from a small injector to a larger injector.
Also, if you have injectors that are too large for your application, you'll have other issues. Short duty cycles and/or low pressure to compensate for their flow will lead to poor injector spray, which kills atomization.
Thanks for the input. Now I have more questions for Roe.
That's why I asked. Ya'll keep me fom making $$$ mistakes.
I thought I had it all figured out but no....:eek:
Have the same problem ie. running lean even with meth.Looking at changing the fuel system completely,getting rid of the fmu and putting more VOLUME to the x-metal rails. AEM pump with fuel line recirculating to the tank. The paxton fuel system is maxed out at about 640 rwhp. Looking for 90psi at the rail.
You might want to look at the entire fuel system for faults.
There are many that are making over 700 RWHP with the Paxton set up.
I am not saying that it is the answer. I talked to the engineer at Paxton and he was surprised that it would make that kind of HP.
I am going with a Paxton in the red truck and am using 3 255 pumps in the tank with a AN10 feed and a AN8 return. 2 would do it but I have a little insurance factor with 3 pumps.
I am going to spray it also, that system will have its own 1 gallon fuel cell and I am going to use the auxiliary pumps that came with the Paxton to supply that part of the system.
I was in the Carburetor and Fuel Injection business untill I retired and I have seen more inconsistant times, and many cooked motors with marginal fuel systems.
Thanks for your input. We are doing a dyno run today to look at fuel pressure at the rail. At WOT we are hoping for 90 psi or better.We had to fashion a pressure guage to the end of the rail as there was no fitting to tie into. Now iI know that this is not a measure of volume but we are trying to narrow down the problem.We have also suspected a problem in the split second box.One fuel pump turns on for only 3 seconds and the second turns on for about 10.Boomer flashed the split second box for us a couple of months ago but I believe he only adjusted timing. We have now jumped the pumps to maintain fuel pressure ---any thoughts.
You are doing what is necessary to narrow it down.
Jumping the pumps will tell you what is happening, with the gauge readings under high RPM, full throttle pulls.
There is a pressure volume test that can be run = a certain volume at a certain pressure for a measured amount of time. I have no idea what that would be on one of these systems, so the way you are doing it is perfect.
Please continue to post on this thread so we can all benefit from your experiance, and how and what you are finding as you go.
You may have to eventually go to a bigger injector, with an upgraded fuel system.
I as well as many others are using, or are going to use the VEC 3 for fuel and spark management, and not use the split second box, or FMU.
This gives us much more adjustability and control.
Also we do not have to run the fuel ressure up to keep from being lean (this does require an injector change). Better a more constitant spray pattern.
In the red truck I will be running about 9-10 PSI of boost on a 540 CID motor, and I am using a 75 LB set of RC injectors that are flow matched. They are pricey at 100.00 a piece but they are very good and have a great pattern.
I had a Vortec blower on a 1998 Ford Expedition 5.4, and it only had an FMU, which worked flawlessly for 112,000 miles. This was only at 5 PSI (no intercooler) so they do work.
QuickSilverIt's real nice having you (Jack) hanging around.....Happy New Year Jack! :rock:
Quick
Thank you very much, it is nice to hear things like that, makes me feel good.
Happy New year to you also, nice to have you here.
You are one of our most senior members.
Thanks for keeping up, adding to, and putting up with the nonsense. ;)
Ram From HellAlso, if you have injectors that are too large for your application, you'll have other issues. Short duty cycles and/or low pressure to compensate for their flow will lead to poor injector spray, which kills atomization.
Exactly............:rock:
I am having to run a 1600 LB injector (at 60 PSI) on the silver truck motor so I will have very short pulse width (duty cycles) at idle. Again I am going with an RC injector as they have the best spray patterns. The 1600LB injector runs 198.00 per injector (I hope they are worth it).
It might be a little dirty emmissions wise also, .800+ lift camshaft doesn't help either.
But I did not want to run 2 injectors per cyl and have to put up with the tuning nightmare that staging them would precipitate.
I could stage them as I am running a Motec M800 box for engine management and traction control.
If I cannot get enough low speed control, I will have to add another set of injectors to the manifold, and stage them.
That will require another injector harness to be made up, another set of fuel rails, and more plumbing.
I really don't want to spend the money for all the hardware and have it look like Captain gizmo's whatthef#$%kisit under the hood.
My philosophy has always been, "parts that are not there, never break, or fail".
How are people getting 700 rwhp on paxton systems? I had my truck dynoed at a consistant 600rwhp with a peak of 641. I then had the vec installed and Sean at Roe dynoed again but shut it down early because of lean condition. At that time he only got 560 rwhp.
I have the 8lb pulley and with the meth have had no issues but # are low.
Sean didn't mess with my meth becuse he we not familiar with FJO.
I wasn't present when he ran it. After the injectors get installed he will retune but I'll be there with the FJO program.
My guy used the staged injector set up. Yes it was a little more work but the truck is at clean as stock off of boost and I still pass the NJ testing.
I ended up designing something different myself, having had Boomer flake out after he initially wanted to do it...
I chose to leave the in-tank pump in place. That pump feeds a 3g cell that the main pump draws from. The cell will only draw down under hard acceleration, and refill under normal throttle. The return from the regulator feeds the cell, with excess fuel being passed back to the main tank when the cell is topped off.
This is fairly close to the rest of my setup. The pump is designed for continuous duty.
http://www.magnafuel.com/products/kits/MP-4813.htm
u gonna need one a dez pumps:D
http://store.summitracing.com/partdetail.asp?autofilter=1&part=AEI-11102&N=700+115&autoview=sku
Thats a very nice way to set it up, you should have many years of trouble free service from that setup. I chose to do triple in tank walbros on the recent turbo truck, the big advantage being cost and reliability, however you must keep the tank near half full or more because of the tank design in order to keep the pumps fed under WOT. Your setup is also very reliable but is much more expensive, however you dont have to keep the tank 1/2 full, etc. Good work!
Justin
As always Justin thanks for taking the time to speak with me. Just spoke to the shop. We are going to take your advice and do away with the Paxton set-up. No more split second box,FMU or external fuel pumps.The plan is to install two internal pumps with new fuel lines,new larger injectors,and a regulator with return to the fuel tank. Timing will be controlled through the PCM. We are contacting DC performace to help work through the logistics. Are we missing anything?? Thanks to all for your input.
Sounds good to me, that should eliminate your problems and you will finally have the proper fuel system for your paxton SRT.
Justin
