Car dies. P0320 code. Crank sensor?
Discussion in 'General Discussion' started by aznbuvu, Oct 4, 2015.
Car Parts
  1. aznbuvu
    aznbuvu New Member
    7
    Jul 20, 2015
    Hey, got an 06 SRT RC. Truck died on all of a sudden and threw this code. Reset it by unplugging battery and after a few minutes, truck dies and CEL comes on again. Planning to change crank sensor. Is that what you guys think?
  2. shorty
    shorty Full Access Member
    2,053
    28
    Sep 1, 2012
    Emory, Texas
    Do you already have the sensor? If not-----big problem. Hope it is something else. No one has them and no idea when they will be available---if ever. :(
  3. chaynick
    chaynick Full Access Member
    537
    Jul 17, 2011
    Naperville, IL
    Is our crank sensor the same as the viper cars CPS?
  4. shorty
    2,053
    28
    Sep 1, 2012
    Emory, Texas
    Asking the wrong guy but check with Scott, one of our sponsors.
    VENOMOUS 1 RACING
  5. shorty
    2,053
    28
    Sep 1, 2012
    Emory, Texas
    e-mail Scott at:
    [email protected]
  6. johnthegoalie
    johnthegoalie Has Left the Room - Banned from VTCOA!
    271
    Aug 28, 2014
    sw desert
    Have you ran the code or just thinking crank sensor?
  7. VENOMOUS1 RACING
    12,753
    May 15, 2009
    Wacko Waco,TX
    Says p320 in title so yes it's cam/crank signal related.
    Try crank position sensor first. They are available still. Cam sensor is not as of yet.
  8. VPRPWRD
    10,835
    Mar 28, 2012
    PA
    I can get a cam sensor, takes a week but it is salty, $175.00 plus shipping.
  9. aznbuvu
    aznbuvu New Member
    7
    Jul 20, 2015
    That's the plan. Hopefully it is the crank sensor and not the cam sensor? Sucks that the truck dies now tho. Crossing fingers it's just the crank sensor.
    Might have to hit Vprpwrd if it is the cam sensor...
  10. chaynick
    537
    Jul 17, 2011
    Naperville, IL
    That's why i asked if they're the same as a car sensors. Auto Zone has CKS for 25 bucks.
  11. Wastelands Warrior
    Wastelands Warrior Full Access Member
    488
    Jan 23, 2014
    Wastelands of NJ
    Rock Auto is showing crank and cam sensors available from Standard Ignition.
  12. NukeGM/Ford
    NukeGM/Ford Active Member
    1,805
    10
    Oct 4, 2014
    North Las Vegas, NV
    autozone swears both are available also, guess i need to order them to find out:dontknow:
  13. VPRPWRD
    10,835
    Mar 28, 2012
    PA
    Plenty of places say they have them, then you order them and the story changes. I do hope they are available for your sake but it hasn't been the case in the very recent past.
  14. V10Brian
    V10Brian New Member
    6
    3
    Mar 2, 2020
    I have had several of these fail in my five vipers/trucks.
    Replacing one out is about the same amount of work as an oil change.
    For some reason the Mopar sensors are not reliable.
    I have had better luck the $20.00 in stock sensors from Autozone.
    Due to all the failures, I always carry a spare sensor in my glove box.
    Important: Make sure the length of the replacement sensor is the same as the old one. If not, it is possible deep engine damage could happen.
  15. THEWELSHM
    THEWELSHM Well-Known Member Supporting Member
    2,425
    30
    Aug 29, 2008
    Brandon Florida
    Rock Auto has Crank sensors I just bought one..
    thewelshm
    Kiwi SRT10 likes this.
  16. V10Brian
    V10Brian New Member
    6
    3
    Mar 2, 2020
    Also important, if the tip of the sensor is damaged, you will need to add a washer to the bolt for a spacer. As the engine gets older, the tolerances get looser and sensor target could start hitting the sensor and damaging it. The opposite can also happen, if the sensor is spaced to far from its target or is weak, you will get intermittent p320 codes.
