mopower1958
- Joined
- May 20, 2006
- Messages
- 2,482
- Reaction score
- 0
Jack on the Coronet I have a 9375 Dominator. In order to get a decent idle I have the throttle stop screws in over 6 rounds front and rear. The idle mixture screws seem to have little effect on the idle,should be 1/2 to 2 rounds out maximum is my understanding, and when its sits in neutral a while the idle creeps up till it gets to about 2200 rpm. It has 3 air bleeds per corner in the top of the main carb body. Do I need to increase the orifice size on the idle air bleeds in order to close the throttle plates further so as to utilize the mixture screws more effectively. If so, do you have a ballpark estimate on size, and are they the outside ones?
