Snakes709
I recently got a set of mopar catless mids from a local member, however they were cut short so they are only long enough to remove the rear cats. I went to a shop to get a quote and they said it would cost $300 to weld the pipes in and weld in a 02 bung for my wideband. However that still leaves the front cats in, they said it would cost about $500 to weld the pipes in and custom fab the section to remove the front cats.
I'm seeing online catless mids go for about $350, but require a extention for the QC. My magnaflow is 2 1/2" and so is the stock pipe, correct? Is there any mid pipes made that are 2 1/2"? If i can find a pipe that size then i can just use my stock extention pipes, correct?
It was nice to get these pipes for free but i would like to get a set that will bolt right in (that way i have the option of taking them out if i sell the truck or require a inspection) and have it cost less then $500.
