CEL for cats showed up today...
viperhauler
Well-Known Member
P 0432...i assume my cats are finally clogged with all the miles, and all...soooo...
anyone have a set of high flow cats and/or mids laying around?
i DO NOT want catless mids, but if someone had some, i will take them to the local shop and have high flows installed...i'm only running the first set of cats anyways...
maybe a header/mids combo...i know that's a long shot...but i'm writing it anyways;)
I've got the two rear cats that were cut out of mine, pm me if they will work and we can see what we can do.
i have all 4 cats. they are OEM, not sure if that would be highflow or not.
they are not broken, and were taken out at 28,000 miles.
pm me if you want to talk about them.
I have the rears still that I took off a long time ago... And I think I'm gonna use this as an excuse to get so better ehaustory components;)
But thank you, gentleman, none the less...
U can install spark plug foulers into ur rear 02 bung with ur 02 sensor and never have an issue. These parts are about $3.00 a package for two inside and u need four. You take the first fouler and screw it into the 02 bung. Then take the second fouler and drill it out with a 1/2 inch drill bit. That drilled out fouler gets screwed onto the 02 sensor, then u take both of them and screw them into the fouler that is already screwed into the exhaust. So everything finally looks like... Exhaust bung, first fouler, drilled out fouler, and 02 sensor. The part number for our trucks is like 00042 or something like that. What this mod does is takes the rear 02 sensor out of the exhaust stream, making the ecu read a significant difference between the front and rear 02 sensor. Make sire also u clean ur 02 sensors by soaking th in gas and scrubbing with a light brush. SORRY FOR THE LONG POST!!! Lol.
i haven't had a code in 3 years...i don't think it has anything to do with the rear cats gone...
i think they're just clogged...what with 91k on it...
but it could be an 02 sensor that went bad, too...
i'm still looking at my options...
or you could just hollow them out and put them back up empty :)
clean em bro... worst comes to worst - gotta buy new 02's
