OK, never done it before but I would like to check mine out after this past weekends adventures. Can someone provide some instruction?
Silverback said:But then, I tend to be anal about some things.![]()
not many of us changing the rears i guess...don't dust nearly as much:rock:Are there instructions for the rears? Everything I see in the DIY only references the fronts, or only has instructions for the fronts...
Silverback said:One thing I do when pushing the caliper pistons back is I open the bleed screw so you don't push the brake fluid back through the system. Two reasons for this. Most of the contaminated fluid is in the caliper, and second is some ABS systems do not like having the fluid pushed back through the system.
Annu Kumar said:Beer?? I thought you would love a few Bananas Silverback![]()
