SRT-11 said:
I've seen a few threads that mention changing out clutch fluid to the neo 610, etc, and I don't have plans to go crazy HP with my truck but I am a huge fan of making everything run as efficiently as possible! Is it worthwhile to change out the clutch fluid, and if so, is there a how-to on it? is it a 1-man job or do I need a buddy? I did a search but came up with nuffin.
Thanks guys!
It is totally worth it bro,
you will need two people, and its fairly easy if ya dont have any special tools,
this iis the backyard method with out tools
get some motul 600 or which ever you prefer
on the tranny towards the front of the tranny on the drivers side you will find the extension from the slave cylinder, get a wrench , rags, and a pan to catch the fluid.
have a person inside deprese the pedal, "slowly" open the valve on the extension, let the fluid drain till it almost stops, tighten , do this a couple times, and then start filling the resevoir before it empties, and repet process a couple dozen times to flush the old out and the new in.
now each time you tighten the valve the person inside must release the pedal then depress again and hold while you open and close the valve.
you can buy bleeders at the local parts stores that make it a one person job if ya want also
