Check Engine Light On "fix"
mpakla
San Antonio, TX
Update : The cat's were removed and the lower o2 sensors were disconnected
on my 2006 Ram SRT 10 causing the CEL to come on. local performance shop tried to load codes from SCT to turn off the lower o2 sensors, but this was not working after a few starts of the truck the CEL would come on. using info from VTCA I purchased to new lower o2 sensors from Advance Auto parts $89.00 and 2 each O2 Adapters item # 270624567796 from ebay for $24.00 with shipping, these shipped from Illinois. You screw the adapters into the bung in the pipe, then screw the o2 sensor into the adapter, connect the sensor to the harness, do the same on the other side, clear the codes and your done. Drove the truck about 200 miles and still no CEL. Hope this info helps.
