Check Engine Light.....Truck surges
jlwilsonjr
Member
Ok this morning my check engine light came on. The truck seems to "surge" in the lower RPM range no hesitation at all when you nail it. I know this is a very vague question but has anyone experienced this before? The only mod that has been done is a Airraid air filter.
Also the code is P0121 which translates to P0121-TP SENSOR VOLTAGE DOES NOT AGREE WITH MAP - SRT10
What the heck does that mean?
Does your idle hang above normal? If so you might have a bad O2 sensor.
Try disconnecting the battery for about an hour (negative) terminal post and reconnect. This should clear the trouble if it is that.
You have a bad throttle position sensor. Your experience is the exact same as mine. $31 at your local dodge dealer. Seems to be a common problem more and more lately.
It does hang above normal little above 1k.
I hope a 31$ part is all it is that would great.
