ck engine light
VIPER
JTS VENOM SERIES SRT-10
South Jersey
ok - got the truck done,... wow,... it's LOUD too it around the block,.. came home and ck engine light came on
here are the codes ....
P0152-O2 SENSOR 2/1 CIRCUIT VOLTAGE TOO HIGH - SRT10
P0132-O2 SENSOR 1/1 CIRCUIT VOLTAGE TOO HIGH - SRT10
P0151-O2 SENSOR 2/1 CIRCUIT VOLTAGE TOO LOW - SRT10
P0131-O2 SENSOR 1/1 CIRCUIT VOLTAGE TOO LOW - SRT10
P0155-O2 SENSOR 2/1 HEATER FAILURE - SRT10
P0135-O2 SENSOR 1/1 HEATER FAILURE - SRT10
i got the code read from the OBDII with my SCT programer
what does this mean,... all these codes ??
are you running o2 sims? are you o2 sensors hooked up?
yea " i called my tuner ' torrie ' " - i connected the wong O2's i connected the back 2 insead of the front 2just wantin on the engine to kool down adn change them up,
i am stund that it seems alittle sluggest tho with the cutouts open
and with the mopar headers the magnaflos exhaust sound complety diff..,
The Mpoar headers make it sound different in a good way?
Mine was running perfectly with catless mids and sims then I put the stock cats and pipes back on (due to a "Altered Exhaust" ticket) and got : sensor voltage too low,soooooooo I bought new sims (I sold the catless mids and sims) and started getting P0138 and P0158 codes : sensor voltage too HIGH ??!! :dontknow:
Have no idea what to do now.:dontknow: :confused: :dontknow:
I can't remember who I sold the mids/sims to either :mad: :eek:
Are these the rear sensors or fronts ?? :dontknow:
Hope to have catless pipes and "H" cross-over before PCB gtg.
im not sure on the sound yet,... im going to have my exhaust redone, next week from the cutout to the tips
the sound out the cutouts id fookin loud ' w0w ' i really have not heard the exh from the out side of the cab... but the sound is diff....
i called torrie at unleashed,.. he told me to remove the rear 2 o2 sensors and connect the front ones then my ck engine light should go out,.. ill findo ut 2marrow....
im havin the exhaust redone bc when i reinstalled the pipes the tips area about an 1-1/2" where the should be,.. :( im not a good with pipes so i gotta pay to have them redone
