KINDA SOUNDS LIKE ITS A MOTOR MOUNT CLUNK BUT I CANT PIN POINT IT. IS THIS NORMAL? SEEMS TO STOP WHEN WARM ITS SOMEWHAT ANNOYING BUT IT DOES NOT AFFECT DRIVING AT ALL
Do you have a video of it? Before I changed to my belangers I had a clunk type noise that would start from a cold start and go away when warm and also after shutting off as the engine was cooling down. Turned out the heat shield on the pass side had a Crack on either side of the manifold which I suspected before the header install.
