Clutch alignment tool
eldermc42
Orangeburg, SC
I recently received a new clutch assembly with an aluminum flywheel free from a buddy of mine, but I'm missing the alignment tool.
Can someone point me where to go to get one, or does someone have one laying around that I can borrow?
Thanks in advance,
Matt
Hey bud, you can likely have better luck either going to a tranny shop and borrowing one for an LS1 T-56 and you will have to wrap a lil electrical tape to fit the pilot bearing tighter as the LS1 is a tad smaller but the spline count is the same. Your local Autozone or OReilys should have one as well. May come with a clutch kit though? Maybe the would let you borrow one as well.:dontknow:
I just installed my clutch without an alignment tool. The one I borrowed was to small at the pilot end so I just centered the disc by finger on the outside edges. Made it feel even all around then tightened it up. Tranny slide in pretty easy. Last 1/2" with the bolts of the bellhousing. I couldn't push it on to the dowels so I used the bolts!
Clutch Pilot Tool Set
$14.99 :rock::rock::D fits eveything usually
Pilot Bearing Adapters (Large out diameter/Small out diameter x Height): 1.167"/0.983" x 1.223, 0.869"/0.805" x 1.201", 0.783"/0.746" x 1.202", 0.712"/0.660" x 1.216", 0.668"/0.589" x 1.201", 0.629"/0.605" x 1.216", 0.619"/0.465" x 0.238", 0.590"/0.548" x 1.210"
best set up there is for the little clutches:rock:
autozone might rent them also:dontknow::rock:
