Hello everyone.
I have a bad top bushing on the wheel side on the top controll aluminum arms. I can not do alignment until I fix that because it affects the aligbnment. Can you tell me is there a way to replace only the bushing or it has to be both top aluminum controll arms? Are they expensive? Where could I buy those parts?
Also I have a bad front lower arm bushings. Is it better to buy some kind of complette kit from Mopar of all the bushing? or just those 2 bushings? Are there any alternatives to Moper or better stick OEM? And are those bushing or complette kits expensive at all? Any ideas on part numbers or name of the parson on the forum I can ask about that?
And another question I got, my clutch is kindof old, and I am afraid than when it will start to slip I have no replacement becasue there is no vipers in my area Ukraine here
So I wanted to have someting in my garage just to feel safe. what would you recomend? Jet a Mopar replacement disk? Or other type of disk? Or a complette system with the pressure plate and a bearigs? What usually goes bad? what brand name you recomend? the truck is stock. I saw SPEC and ACT at a good price. but I am not sure if I need just the disk to have or a pressure plate and bearings also and maybe a flywheel? What usually weak off on those trucks? Can you share your experience?
