I have a 2006 RAM SRT10 RC. I had the clutch replaced about 11,000 miles ago and this is the first winter I have had the car. The following issue has happened twice, and is moderately annoying.
Conditions: Temperature is less than 30 degrees and the truck has been sitting without running for at least 12 hours. In each case it is left in neutral, e-brake engaged, parked on level ground.
Symptoms: Starting the car is fine. Clutch feels normal for the first throw, however the gear shifter is incredibly hard to get into gear, and as soon as it gets into gear it will start rolling under power, even with the clutch pedal down. Subsequent throws of the clutch have the pedal pressure weakening more and more until it is flat. A check of the fluid level at this point yields very little of the stuff missing (maybe 1/8 cup of fluid). After topping it off and ramming the pedal up and down, the car is drivable again, but is still somewhat touchy about gear selection.
Any mechanic would probably tell me there is a line leak somewhere (and they may be correct, though I haven't seen any evidence in the driveway). but why if it were a leak would it be doing so in only cold weather. I am out of ideas and patience with what I am beginning to believe is the worlds worst truck in the area of reliability and quality. This symptom is annoying, very annoying. And it only seems to happen when its bitterly crappy cold outside.
Any ideas?
Any ideas?
