After a crappy day today, the fitting end came when I had my truck towed to my dealer. After a long and trying commute, I finally made it back to my truck, jumped in, pushed in the clutch, slid it into neutral and fired it up. As I pushed in the clutch I thought, hmm, that was a nice and easy pedal depress. After the truck fired, I pushed the clutch in and out several times. No pedal, spongy, straight to the floor with little effort. Well this wasn't going to be good. Opened the hood and removed the cap from the clutch reservoir, looked in, didn't see any fluid at the top. Took my index finger and checked it -- reservoir was dry as dry can be. I called my dealer and the Chrysler towing/motorist assistance numbers, set up an appointment for service tomorrow and had Chrysler tow my truck to the dealer gratis (courtesy of my 3/36 base warranty).
So are my clutch hydraulics history, reservoir, master cylinder, slave, all of the above? And where did the fluid go?
While I was waiting for the tow truck, I checked for leaking fluid, found none around the reservoir/cylinder, lines going to the slave or around the bell housing/engine and no drips on the concrete where I parked, no signs of splatter on the frame or surrounding surfaces. This morning the truck shifted and drove fine, not a problem one. The truck has 15.6K on the odo and I use it as a DD, including rush hour, bumper to bumper traffic. I don't abuse the vehicle or race it either. :dontknow: :dontknow:
