Clutch kit and flywheel
Ylw-Fvr
Anyone have a new aftermarket clutch kit and flywheel for sell at a good price?
Your stock flywheel cab be resurfaced at least once, unless you are wanting something different.
Yes Sir. Got a brand new Centerforce and brand new Flywheel that I have
been meaning to sell.
ALL NEW!:rock:
Lookin for 750.00+ shippin.
looks good. It is all there ?
thanks,
Mark
thanks,
Mark
The centerforce clutch is brand new and has the disc and pressure plate.
The Flywheel is brand new.
You should get the upgraded viper clutch cylinder and slave. "JMB" or "ROE"
Also new clutch and flywheel bolts are a good idea.
A clutch alignment tool is also helpful.
This flywheel and clutch was for my 06 RC, but I do belive it should be the
same for all years.
I will make some calls to find out.
What year ya got?
thanks,
Mark
In the pics I sent the disc is under the pressure plate.
You cant see it because there is factory storage paper between them.
Kit is brand new and was purchased from "Justin" "JMB".
I have been back and forth on using this clutch only due to the amount of
power I may end up with.
I think if you stay under 800hp this clutch should be good.:burnout:
Thanks I hate to put you thru this much trouble but mine is an 05.
Mark
