Clutch Pedal Switch w? JTSVP's hydraulics
yellowfever#154
Lacombe, Alberta
I am curious if anyone has removed the factory clutch pedal switch and moved it over to JTSVP's upgraded cylinder setup?
Years ago when I installed Tonys setup I simply disabled the switch as I was in a rush. Now I want to get it working properly. But after a quick look at the switch Im curious how it is removed from the factory master cylinder and if it will fit Tonys master cylinder?
Yes, I did this on stealth's truck before I sold it. I did it in reverse order though, removed the switch from the JTSVP hydraulics I was removing and installed on factory hydraulics. There is a clip on the top of the switch that slides out and it can be snapped in around the push rod then the clip is reinstalled.
There is also a plastic washer that must be put on push rod, if it's not the switch doesn't travel far enough to allow the truck to start.
