clutch won't bleed out
ARRESTmeRed04
central texas
ok i had to put another new master cylinder on my truck and i'm having a fit trying to get it to bleed, tried the one man bleeder pump thing called a friend over to help, almost went through a whole big bottle of fluid and still no clutch, i'm about to kick the door in on the truck, anyone have any ideas????
I'll give youdetails on how I do it and so far it works well..
first fill the bottle with fluid, leave the cap off,
put a small containor under the bleed screw to catch the fluid, and open the bleeder fully, let it drain out until the resevior is almost empty, fill and let it keep draining,
when it is almost empty again, close off the bleeder.
then have a person inside, ( and he is themost important part) SLOWY! I cant stress thatenough! very very very slowly , depress the pedal about 4 times. then while the pedal is depressed , open the bleeder, and BEFORE it finishes, close the bleeder.
do this a half dozen times after all the air has escaped and see if this helps:)
but do not release the pedal or depress it quickly! it will cause the fluid to cavitate and cause air bubbles in the system , and you will bleed forever to get them out;)
ok i'll try that when the old lady gets to the house thanks stink, never got to try out my suspension mods since the master crapped out on me the day i was gonna race.
stink can you make this a sticky?:hello: :questionmark:
i have gone through some cylinders also recently on this centerforce/viper slave setup. THe clutch has been wearing out the cylinders....i just ordered new parts putting everything back to stock...fed up with the centerforce and viper slave...i don't think they do what they claim!
