comp cam
Ironhead said:
same cam i have in my truck now :rock:
i was goin to run it but since im taking the s/c off and goin turbo i dnt see this bein the right cam for me
you are right it is a N/A ,,,wont work that great with S/C or turbo ;)
yea hoping i can get it in the hands of n/a build i believe the price is pretty good, gotta start moving stuff for the wifey will let me order the turbos etc
kickinassrt-10 said:
What will a cam do and is it saw on stock engine?
its all in what u want a cam will had hp to ur truck how much i dont know, u would prob want to do a tune on the truck after the install and maybe a exhaust so u can hear the cam a lil more. ironhead has this cam in his truck jus dnt know what all it done for him my first intentions in my truck was to stay n/a but i blew that with the roe and now im goin turbo :dontknow:
Not sure what saw on an engine is ,,,lolK/K
with pp heads and cam i gained almost 40 to 50 hp on a cold day on a dyno ,,tune is is a must !
Is the spec sheet correct? The engine family listed is 1992 - 2002 V-10. :dontknow:
i dnt know why it says that if you go to there site and look at viper truck u will see the camshaft at the bottom, i dont know if the camsaft change a whole lot between the years i know ironhead is running the same camshaft so it must work:)
It is a good camshaft for our trucks. A steal at 350. Probably 550 new.
yes this is a steal for the price.. i'm running custom cam based off of this cam and i love it!
I'm going to have to pass on the cam bro, my builder said that i'll be going with a cam a little bigger than that;)
some times bigger isn't better! hahaha:rock:
Just bought the nitrous or I'd be all over it. What all do you have to do to the heads cause it says you have to modify them???? and what other components do you have to upgrade. Basically what I'm asking is how much will a cam install set you back total? I had a cam in my ws-6 and my power steering was pretty much gone due to the low idle...
to be honest bud have no idea what all would need modded pm ironhead i know hes running the identical cam in his truck, ive not swapped the cam in my truck yet so wish i could give you a better idea but then id be lying:)
