Comp reprogram kits
nycstev
ZOO YoRk CiTy
What kind of mod are available for stock engine ...right off the bat without going to wild?Computer reprogramming or is this basically maxed out asit comes:dontknow: ?
Do you have a QC or RC? QC's get the most benefit out of the PCM flash. If you are not looking to go wild I would get these 3 things.
1. Stage 2 flash
2. Exhaust and cat delete or at least hi-flows
3. Intake (CAI or Drop-in)
CAI=Cold air intake. There are several out there. It is just a replacement for the stock air box. I had the K&N and liked it. Do a search and you will come up with several different types. Stage 2 flash is referring to the computer you asked about. The computer (PCM) can be flashed on different levels. Basically how aggressive the tune is. When they first came out they had stage 1 and 2. Stage 2 was the more aggressive of the two. Boomer and DC performance sell the flashes. And with you having a QC I would get the flash. Here is a list of what the Stage 2 does:
Revised premium fuel & timing tables - (91 or 93 oct)
Shift points raised to 5950 rpm
Rev limit raised to 6200 rpm
Torque management removed automatic only
Cooling fan duty cycle modified
(The stage 2 flash has Produced 80HP gains & 100 Ft Lbs torque as A/B tested @ DC Performance on a Dyno Jet with a 05 SRT10 Quad Cab automatic.)- Your results may vary. B&G does not guarantee these numbers and uses these numbers as 3rd party reference only as numbers will and may vary between Dyno’s and Dyno Shops.
yeah, just as what flyinglow said, stage 2 flash it would wake up your truck a lot. you would notice the complete different, as for cai, there is K&N, volant, jmb. jmb is nice because you could match it color to valve cover and it include with oil catch can
Thanks..Would cat delete effect emmisions here in NYC.? And who sells this
Stagde two....?
THANKS
go to the bottom of this page, click forum jump and then select x-metal engineering, this is his web-site;)
