1fast10
Nice Coronet
mopower1958 said:You can kill a lot of STATIC compression with camshaft duration. I run pump gas in my Coronet with 11.5 compression, but the duration on the camshaft 268/276 @ .050 makes the dynamic compression (compression while running) 8.5 to 1. Here is a dynamic compression calculator that may help you.
http://www.speedwaybids.com/DynamicCompressionRatioCalculator.php
andrew heywood said:your 67 coronet is really, nice I love that year because it is the year of the R/T,all you knowledge on motors is lucky for us, the indy motor is 13.1 comp higher?
pokeytemplar said:Very interesting, by increasing duration you are effectively reducing the amount of stroke that is used for compressing gases. Only the stroke/volume left after both valves are closed is counted in the dynamic compression ratio. So looking at Kyle's cam card his factory ratio of 9.5 is 7.38 dynamically.
Then what is the highest DYNAMIC compression ratio that can still run 93octane? Still 10:1 or significantly less?
