It calls for the Dex Cool Extended life orangish red stuff, but Prestone green in the yellow bottle is approved for all of them. Id still get the good stuff. Get a Prestone Flush and fill kit. it has a t fitting that installs in a hose. Your water hose hooks up to it and it back flushes the entire system through the radiator cap till it runs crystal clear.
I make sure the truck is cold, drain the old in a container so you dont pollute
Close the drain plug, cut the water on, crank it, and let it run, until its clear.
Drain enough so that you can add the Preston super cleaner/flush, the big bottle.
Let it run 15 minutes AFTER it gets to operation temperature with the heater on high **IMPORTANT**.
wait for it to cool Then flush it again till its clear. If you dont wait you risk cracking or warping your block or heads.
Drain it and fill it with 50% anti freeze and DISTILLED water. Just dont waste your money on the 50/50 premix. its half water
A trick i use to make sure i got the mix right, is i buy 2 jugs. Dump one in the radiator. Then put a gallon of distilled water in the radiator. Pour half the antifreeze into the other jug, and top them both off with distilled water. Now you have 2 jugs of 50/50 for the price of one. top off the radiator with your new 50/50 mix and fill overflow jug up to the line. Crank it let it get warm and check your levelsand keep what you have left in the bottles in your garage. if you ever get low, its there.
