seethrough
Member
You can try to rinse off your condenser coil - dirt buildup in the fins will reduce it's ability to disperse heat and give you a high head pressure. You can also check your refrigerant charge. Is the engine temp high? The fans are positioned so they have to blow air through the radiator before going through the condenser coil so a higher engine temp may cause this as well.
