Crank Pulley Tool?
DIABLO_X22
Carbondale Illinois
Is There A Special Tool/Holder When Torquing The Crank Pulley Bolts On A 2005 QC? Im Checking Mine Tomorrow Morning, After Reading About Them!
put it in gear ?????
Isn't there a access panel on the bottom side of the transmission to access the torque converter bolts? If so remove the panel and have one of your buddies crawl under with a prybar and hold the ring gear while you torque the bolt.
perk_1405 said:
loosen the bolt and then put it in drive:D then do a burnout
:burnout::burnout::burnout::burnout::rock::rock::rock:
