I finally got around to installing my new speakers in the dash. Turns out its really simple. For those of you that want to try this do it. The top part of the dash by the windshield just pops up with a little help via a putty knife. Just pop up all the connectors then pull toward steering wheel. (More connectors hold it in snug). Then its two screws, unplug factory connector and the speaker is out. I used some wire connectors to attach speakers since Crutchfield does not make adaptors for the dash speakers. If you look on factory speaker plug you will notice a G on one side which I assumed was the ground side. For some reason Dodge has 4 different colored wires between the two front speakers.:dontknow: Plugged everything in, fired up the radio and walla everything worked. Ours trucks do have a center speaker which I understand has its own seperate amp. There is no replacement for that speaker that I know of. This speaker sucks IMO. Anybody got any ideas? Maybe I should just unplug it?
Easy simple mod IMO so change out those speakers if your not satisfied with the stockers.
patrick
patrick
