Let me sees if I can remember without having one in front of me
remove the tb via the 4 bolts, bottom right is the worst.
remove the vacuum lines and the tps sensor connector
remover the tb
remove the tps sensor via the two small torx heads and slide out
next mark the two blades so that you will know which side they return to.
then take a small file and file off the backside of the screw that hold on the blades.
Now this is the pain bruddha, slowly work the screws out a small amount at a time, this is very important they are soft and snap off easily?, use some WD40 or some kind of lube, work them back in , and out until they are all the way out. now dont get cocky and think they are commin out and jsut start screwin away, you will get right to the end and they will snap if ya do that
so slowly all the way out.
next after the screws are out, flip open the blades, and work out the blades, the shaft is split down the middle and the blades jsut slide out.
Next with a rubber mallet tap the end of the shaft where the tps was, the shaft may jsut slide out, but I always ended up tappin it a bit.
Also take note of how the spring is wound on the shaft, it must go back the same way.
then slide out the shaft.
Now the bearings are a pain, and you most likely may mess them up, so if powdercoating you may want to plug the ends with something and leave them in there.
if not
then you will need a small blunt punch to get into the lip of the bearing, and slowly and easily tap them out, but be carful they are a tad fragile
