was wanting to upgrade my door speakers. what would be a good choice?
are there 2 speakers in the doors or are the 5 1/4 in the rear doors.silverqc said:what ever you use dina mat behind them , makes the sound , i did alpine type r 6x9 and alpine 5 1/4
eddie102870 said:are there 2 speakers in the doors or are the 5 1/4 in the rear doors.
:rock: :rock: Thanks man! I am going to attempt this in the next 2 days. Should be interesting! Thanks for the tips!Cablefed said:I have those same speakers in my door AMTRUCKER. I made some adaptors using 3/4 inch MDF. The depth of the magnet on those speakers are almost to the point they touch the window inside the door. The other issue is when you make the plate you offset the speaker a bit so its away from the window actuator so the mechanicals don't rub against the speaker. Mine sound awsome with the tweeters in the stock dash location. Just a few tips before you build your adaptors. I used the stock 6X9 depth ring on the stock speaker to make my core template and then played with the speaker location until I got it right. I had to trash one template as it was all cut up until I got the right combination. Cheers!
