moparracing
got my driveshaft loop today, but no good install steps or pics..... can probably guess most of it, but pics from ya'll that's done it before would be helpful - please......
thanks.
thanks.
Stinker said:let me see if I can help![]()
laying under the truck with head at tranny an feet at rear axle![]()
the large flat plate, the part with the four holes should go at about your waste to the crossmember at the rear of the cab, the two smaller braces are used to mount this with, the plate will go on top, the small braces locate on the bottom:dontknow:![]()
then at the front of the plate with two holes, the u brace should fit over the driveshaft and mount to the front of the plate with two bolts.
then mount the lower part of the u plat to the upper part![]()
moparracing said:it's meant to catch the front of your driveshaft if the front u-joint grenades, keeps you from pole vaulting your truck....... most tracks require one once you're under a certain time &/or using drag slick/radials.....![]()
