Drop install POA (plan of attack)
bigike
Katy (BY GOD) TEXAS!
Rear first.
Looks like ive got to
1. Put truck on stands
2. Remove the shocks from the axle, lower mount.
3. Put jack under pumpkin.
4. Remove ubolts, and support axle on tubes if needed.
5. Remove the shakle, forward spring mount, and then springs, disgaurd the old mount.
6. Raise the alxle to clear flip.
7. Install flip bracket and ubolts snug
8. Remove bump stop and replace with new bump stop.
9. install forward leaf mount
9. Install Drop shackle and hook shakle to frame
10. Install shock extenders and shocks.
11. With e-brake applied set pinion angle to something resembling stock?
*easy way to set this*help*
Front
1. put'er up on stands.
2. remove wheels
3. Remove lower sway link
3.5. Remove the tierod.
4. put jack under the lower c-arm, take up a little presure.
5. remove the (UPPER) ball joint bolt. (this is dif than my ole chevy's i've done. The lower ball joint is upside down)
6. Let a little pressure off the jack, and tap upper BJoint with a dead blow.
7. Remove stock spring and install new one.
8. Put jack under lower c-arm and reinstall the upper BJoint.
9. INstall the sway link. (is there a way to add washers to the inside portions of the link to space it out and releive the bind.)
10. Slap on wheels and prepare to get my teeth banged out of my head.
*what do i do about the snubbers in the front, they don't look removable and there is metal around 1/2 of the snubber. Can I remove the rubber, cut with my Portaband 1/2 of the metal part off, then cut the snubber down a little?*
this is what i'm using as a helper.
http://www.djmsuspension.com/Articles/02DodgeHemi.htm
I did see that there is a flat peice of metal that goes under the leaf with the flip. I don't see one in my Mcghauphy kit, do i just reuse the stock one? Along with the u-bolts and all that jazz?
is it easier to remove the two bolts that hold the upper a arm or remove the upper ball joint nut?
