Driving home last night and the damn truck just died. It was like I just turned the key off. I coasted into the closest parking lot and popped the hood, I figured it was a wireing problem being that just before the truck died the check engine light went on and it started running real rich. This was a problem I had back in october, I thought I had a bad injector but it ended up being a bad connection in the wiring harness that goes to the ecm.
So I wiggle around some wires and try to start it again, no dice. So I pop open the fuse box and see that the 30A engine relay fuse was blown, so I swapped that out with another 30A fuse and fired it up. After running for about 15 seconds the fuse blew again so I'm going to have to get this thing towed back to my place so I can see what the hell is going on with it.
I think that the problem is going to be found in the old VEC2 wiring harness. I used to run the VEC2 but took it out. So I might just take the wire harness out and solder the wires back together to see if that fixes it. What a pain in the ass! My patience is running thin with this truck.
If anyone else has had this problem, any advice would be appreciated.
