Troy's QC SRT said:Details details fella!
JTS VENOM PERFORMANCE said:is that the off the shelf comp cam?
:rock: :rock: :rock:mysrt10 said:Ok. I can check back with ya on Tuesday about the springs. I've already got the pushrods also. Thanks.
mysrt10 said:It is. It's the 270hr.
Question for you Tony. Can you still get the reverse beehive springs that don't require machining?
it is a slug in sixth gearHucksrt10 said:i have made the switch to 4.56 gears from 4.10 ,and yes the 4.56 feels alot better for around town driving and makes 6th gear useable. the 4.10 makes the truck feel like a slug in 6th gear!
Jigsaw89 said:I'm interested in hearing how the cam works out.
Also, how do you like the 4.88 gears outside of the 1320 track? I have the OEM 4.10's in my 2004 and am trying to determine if 4.56's are preferred over 4.88's for all around driving.
Thanks!
Dan
Ironhead said:man i hope you told them you wanted one set up for 1.7 rockers ,,or your going to have a bit of trouble with it :dontknow:
