Engine code
kyle's srt10
Well-Known Member
Arkansas
I just turned my ignition on and off three times and it gave me the code p0302.. What does that mean???:dontknow: I appreciate the help you guys give!!
Cylinder #2 misfire.
J.R.
So should I pull the plug and check it? Any other suggestions?
1st cyliner on the passanger side (front)...Pull the plug, see if its rich or lean, then wires, etc..
redsrt007's right. #2 is at 1st cylinder on passanger side. Also you will notice that passanger side are order in even number #2,4,6,8,10 and driver side are order in odd number #1,3,5,7,9.
Thanks for all the help! I am going to check it out when I get off work. Is there any way I can get the CEL to go off myself?
I pulled the plug out and there was hardly any gap at all looked and smelled fine so I regaped and put it back in. I disconnected the battery ground for a few minutes and put it back on. Started the truck and no CEL and runs smooth now:rock: Thanks again for all the help:rock: ;)
