Engine knock
Discussion in 'General Discussion' started by moparman95, Jan 18, 2011.
Car Parts
  1. moparman95
    moparman95 New Member Supporting Member
    100
    Sep 5, 2010
    Surprise, AZ
    So I have been having this high idle problem for a minute now. Lives around 2g rpms, I goose the throttle, and it comes down. Change out TPS.. no luck.. Take off my IAC and its fuckin filthy. Literally DIRT in the hole. SO, I clean everything, disconect battery, and go for a drive.
    On the way home, I hear a squeel, like my exhaust is loose or something, almost metal on metal squeel. Pull over, pop the hood. Almost def coming from motor. I seriously thought I was gonna seize this thing up on the way home. This morning, fire the ol girl up, and it sounds like I got marbles in my valve covers.
    So, i figure lifters.. but what would cause that squeel? Any special thing I gotta do to the rockers when I start replacing lifters and pushrods? On my Dak, I just tightened them down until they stopped chattering.
    As far as oil goes, 0-40 mobile 1, with Lucas additive. Looks clear still, smells good. Compression test was done last week, i got between 175 and 150 psi.
    ...and she still idles high. FML.
  2. JTS VENOM PERFORMANCE
    JTS VENOM PERFORMANCE Active Member Preferred Vendor
    33,544
    SRT10 heaven
    did you ever check the backside of the idle screw on the throttle body?
  3. moparman95
    100
    Sep 5, 2010
    Surprise, AZ
    Yes sir.. I cleaned it off. Wasn't really anything on there anyways.
  4. JTS VENOM PERFORMANCE
    33,544
    SRT10 heaven
    cool, maybe try a reset on the pcm, remove the battery cables, touch them together for a bit, then reinstall, try that on the idle issue.
  5. VENOMOUS1 RACING
    12,751
    2
    May 15, 2009
    Wacko Waco,TX
    Also, if you haven't already, be sure to pull the IAC (idle air control valve) on the throttle body and clean it as well. It may need to be replaced.;)
  6. JTS VENOM PERFORMANCE
    33,544
    SRT10 heaven
    as far as the noise its hard to determine, when you cleaned out the iac you could have let some stuff into the intake and it has worked into the combustion chamber which is possible, but you said a squeal, so not sure on that:confused:
  7. Brat
    Brat Active Member Supporting Member
    17,857
    10
    May 29, 2006
    wesley chapel,fla.
    :rock::rock::rock::rock::rock::rock::rock::rock::rock::rock::rock::rock::rock::rock::rock::rock::rock::rock::rock::rock::rock::rock::rock::rock::rock::rock:
  8. moparman95
    100
    Sep 5, 2010
    Surprise, AZ
    Well, thats not something to celebrate!! I touched the terminals together. Pretty sure IAC is just fracked. Taking off rest of this week. Replacing lifters.. getting heads worked while they are off (anyone got a set to trade off?)... Was on VCA website browsing thru, and one guy had the same problem of the squeel and it was his lifters. Ugh.. At least while the SRT is down, it gives me reason to :rock: my 66 Fury.
  9. JTS VENOM PERFORMANCE
    33,544
    SRT10 heaven
    I have a set that we can install new valves springs , even ported if you want
  10. Final GTS
    Final GTS Full Access Member
    259
    Oct 25, 2007
    Buffalo, NY
    Harmonic Balancer Bolt is loose.
    Check balancer and bolt. If loose, remove balancer and inspect crankshaft for damage. Replace Balancer regardless. Replace crank if crank damage creates more than .001" of clearance on crankshaft. Pining the balancer if no longer press fit is REQUIRED, recommend pinning regardless.
  11. McLuvin
    McLuvin Full Access Member
    262
    Dec 17, 2007
    New Hampshire
    hard to believe the lifters are causing a squeel sounds like the belt may have been making noise. Maybe the alternator or ac compressor?
  12. moparman95
    100
    Sep 5, 2010
    Surprise, AZ
    Man.. that shoulda been the first thing I checked. Good call. Already had an issue on my 95 Dak.. replaced all the lifters and it was my crank pulley.
  13. moparman95
    100
    Sep 5, 2010
    Surprise, AZ
    I know, right? Only starts to squeel after a driving a few miles. It's weird man. Been wrenching for the past 12 years, seems I find something everyday that makes me scratch my head.
  14. ZCx
    ZCx Active Member Supporting Member
    9,803
    19
    Sep 13, 2007
    Big D
    got a bit over 30 on these friggin trucks, every day. every friggin day, lmao
    :rock::burnout::congrats:
  15. WOT
    WOT Member Supporting Member
    522
    Feb 1, 2008
    You replaced lifters due to a squealing sound?
  16. phxpoolguy
    phxpoolguy Full Access Member
    3,747
    May 6, 2009
    phoenix
    Your dyno numbers were never what they should have been so it might be better to take it apart and see if there's something wrong internally, better to find out this way that at the track this weekend.
  17. moparman95
    100
    Sep 5, 2010
    Surprise, AZ
    No no.. it started ticking.. as it warmed up at higher RPS (3K) it would start to squeek too.
  18. moparman95
    100
    Sep 5, 2010
    Surprise, AZ
    How much for your ported heads? Ported, springs etc... Would you take my old ones as cores?
