engine light
stick
pensacola
well I guess DC did not make the pcm not read my sensors, because my engine light came on. The truck still runs great and all my gauges and fluids are fine so i guess its my sensors for my cats.
my buddy 2 weeks ago used some things that are for spark plugs and seen a thread about them on the srt forum, have any of you guys used them? My buddies light has not come on.
I will be calling DC tommorow and try to find out what they acttually did to my computer. when I talked to dan he said he was going to make it for it did not read the sensors at all.
if i just went down and got flowmaster will I still see the same HP increase as i did with deleating my cats off the borla
it did not show a code. just the engine light came on. unless i dont know how to read the code
mmmmtorque said:
Are you running sims for the cats ?
What was code of the CEL ?
no ,i thought dc programed my comuter to not read them.
what is the CEL
what is the CEL
Wasnt aware they could program it not check the O2 sensors. Would double check with them....Otherwise you can install a set of sims without much trouble.
CEL= Check Engine Light
Turn the key on and off three time, Do not start the truck just click the key on and off three times leaving it in the on postion the last time. You should get a code showing in the odometer area. Tell us what the code is.
were does it show the code . I looked for one and dont see it
the spark plug thing I was talking about is a spark plug non-fouler. That other thread i cant find now said to buy 2 packs 4 total. drill one out put the sensor in that one and screw the other one in to that and then screw that into the exaust . That is what my buddy did and he has put 400 miles on the truck with no problems
stick said:
It only shows my miles,,,, nothing else
do the key trick, here what u need to do is turn key on then off but not start the engine, do it three time when u are done with key on and off three time then the miles should be change to codes then write it down and tell us maybe some of us know what it means
Nice talking with you Stick. Here are the pics of Boomers sims like I mentioned. Since I have not installed yet I dont know exactly how it works but, the directions look simple........screw factory sensor into his sim piece, then screw the unit into the midpipe. Bag of bolts is for the attaching midpipes to the stock manifolds. Wire extensions are self explanitory, at least thats what I am assuming ( I am no mechanic, I just wing it!! ).
I really like the idea of Dc Perf. turning off the reader of the sensors in their flash. I hope this is really possible.
patrick
