Engine swap??
SRT-IZ
Tucson, Az.
Im thinking of installing this...23,000 hp @ 105 rpm:rock:
What ya'll think???:D
The only problem I see with it is that it runs on Diesel, and that stuff is expensive!:D
yea? but what's the power to weight ratio on that bad boy ? :dontknow: :p
Here is an even bigger one!!
http://people.bath.ac.uk/ccsshb/12cyl/
Some facts on the 14 cylinder version:
Total engine weight: 2300 tons (The crankshaft alone weighs 300 tons.)
Length: 89 feet
Height: 44 feet
Maximum power: 108,920 hp at 102 rpm
Maximum torque: 5,608,312 lb/ft at 102rpm
That rougly 1hp for every 4lbs, and 12.2lbs of torque for every 1lb...
Consumes 1,660 Gallons of Fuel every hour!!! at a minimum!!
won't have a traction problem
Whitesnake said:
too small!!!!!!!!! just like mikey's penis!!!:D
Hey didnt you just get yelled at by Jack about this??:D LOLOLOL.....
about what? i kept it on the subject! too small (the motor) and i gave an example (mikey's pee pee)... now what's wrong with that?
P.S. did you get enough toys for X-mas?
