Welcome, just go to the track and work on your reaction times. Also take an airtank so you can play with your air pressures.
The fronts will roll better with more air pressure, the rears will bite with some where between 22 to 26 pounds depending on conditions.
You can also do little tricks like iceing down the intake manifold between passes, this will make more power, removing your airfilter element while at the track will also help.
If you don't have a tonneau cover, some guys tried taking their tailgates off for less wind resistances.
Also, don't do too long of a burn out with stock street tires, they work there best when warmed up good, but not real hot or they get greasy.
Main thing just go and have fun, then report back to us about how it went.
Bill.
