#2784 bought Feb 2007 w/9374 miles
Currently 37800 miles. Engine rebuilt at 34142.
Current mods:
Forged Wiesco coated pistons 10.25:1(static) 10.65:1 total
K-1 Forged rods
Coated bearings
Gen 4 gold head gaskets(.4 compression bump)
Comp cams XR 270 cam
ATI balancer w/ROE crank pin kit
Comp push rods
Comp beehive springs
JTSVP ported intake
JTSVP dual electric fans
JTSVP coils/wires
JTSVP oil and power steering lines
X-metal Thottle body
SCT tuned by Torrie
Optima Red top battery
JMB CAI/catch can
JMB sway bar end links, front and rear w/energy suspension bushings
JMB line lock
JMB stage 1 traction package w/QA-1 diff shock
Energy suspension poly steering rack bushings
B&B long tubes/catless mid(3")
3" x pipe into Flowmaster 40's
Spec stage 2+ clutch
Fidanza flywheel
X-Metal Gen X shifter w/ viper head knob
Cherry performance drive shaft loop
Rebuilt diff with bearings and clutch packs
Cryo'd spider gears
4.88's
BFG G-force TA tires - 5/32" remaining
EBC yellow pads (front)
X-metal front springs(1" drop)
Leveled in rear
Cal-tracs
Triple gauge pod
Autometer Wideband AFR
Autometer Vacuum/boost
OEM oil temp
Hardwired for a V-1 detector(not included)
Raptor shift light(blue)
Pioneer DEH-6000 head unit w/ipod, iphone adapter
Blacked out headlights/fogs
Blacked out third brake light
Blacked out Recon LED taillights
Cal-vue mirrors(power)
additional parts: OEM coil springs, OEM flywheel, OEM camshaft, OEM throttle body and blades(shaft is in X-metal t.b.), OEM trailer hitch assembly, M&H 12 x 16 slicks, a few different aftermarket headlight/foglight bulbs, (2) OEM goodyear spare tires(1)mounted, (2 mounted) Bridgestone Blizzak winter tires on OEM steel spares
The body has imperfections, a small dent on the passenger fender just above the cladding and some clear coat has begun to come off of the front bumper(not very noticeable), minor rock chips as with most street driven vehicles. She's a beast, just need some life changes.
Fresh fluids for: coolant, differential, power steering (March 2012), clutch hydraulics (July 2012) engine oil, trans oil (Feb 2013)
I'm sure there are a few other things I'm forgetting, so just ask.
Title in hand.
$25,000 firm, not interested in trades + cash, not currently interested in part removal/swapping.
Chris 256-656-4007, located in Joliet, IL
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
Current mods:
K-1 Forged rods
Coated bearings
Comp push rods
JTSVP ported intake
JTSVP coils/wires
SCT tuned by Torrie
JMB CAI/catch can
JMB line lock
Fidanza flywheel
Cryo'd spider gears
4.88's
Leveled in rear
Cal-tracs
Triple gauge pod
OEM oil temp
Title in hand.
