This may help
From DTS services
BASELINE AXLE ASSEMBLY TO INCLUDE:
COMPLETE HOUSING W/ ALL BRACKETS, AND BILLET STEEL HOUSING ENDS
NEW DETROIT LOCKER 35 SPLINE W/ 3 CHANNEL ABS PROVISIONS
NEW 35 SPLINE ALLOY AXLES W/ PRESSED ON WHEEL BEARINGS
(AFTERMARKET BRAKES MANDATORY! / STOCK DISK CANNOT BE USED.)
ALL NEW BEARINGS AND SEALS W/ SOLID CRUSH SLEEVE
CUSTOMER CHOICE OF GEAR RATIO
NEW 1350 SERIES YOKE AND STRAP KIT
STEEL REAR COVER (OR CUSTOMER SUPPLIED FACTORY COVER)
FULLY ASSEMBLED AND PAINTED BLACK
UNIT RATED TO HANDLE UP TO 1200 FLYWHEEL HORSEPOWER.
RETAIL $2675.00 (FORUM COST $2460.00)
OPTIONS:
FORD 11" DISK BRAKE KIT INSTALLED
$400.00 (FORUM $375)
__________________________________________________ __________
WILWOOD PRO-STREET PARKING BRAKE KIT
DRILLED, SLOTTED, PLATED ROTOR
BLACK CALIPERS
$820.00 (FORUM $775)
POLISHED OR RED CALIPER UPGRADE
$125.00
CRYO RING & PINION
$200.00 (FORUM $175)
T/A SUPPORT COVER W/ "DTS" LOGO
$160.00 (FORUM $145)
(this cover puts pressure on the bearing caps for more support)
POWDERCOAT HOUSING
$150.00
MOST COLORS / CUSTOM COLORS WILL BE QUOTED!
____
Retail $ one complete axle with wilwoods and powder coated axle is $4130_____________________________________________ _ _____________
__________________
But the Forum prices on this same combo is only $3830!!!
And a very low buck basic axle will only be $2835!!!
but that is only the housing,ford brakes, detroit locker,any gear ratio, huge axles.
You are welcome to put together your own package
most get the axle,housing, detroit locker, wilwoods, powdercoated red, cryo ring and pinion, support cover and that runs $3680
I doubt there will be another group buy on these, they set the prices as low as they could, hope this helps clear up any misconceptions
These are the prices we can get the axles for and the options, there are more options if you can think of it, or find it on their site, we can get it.
I did round off a few of the prices say if it was $137 to $140 that way I could make a donation to the forum with whats left over.
It should take 4-6 weeks to build an axle, maybe less.
Shipping will be extra.
I will need the axle paid up front.And the axle starts build when they recieve the $.
They also have an install kit with e brake cable, u bolts , brake lines for $350.
This axle option will also allow for 15 rims for the track.
