STOCKSRT10
is the frnt emblem just stuck on or does it have pins on it and whats a good way to get it off
mauiSRT/10 said:Dont using the fishing line method. The area its glued to is plastic and will scar. Use a blow dryer. I put one of Justin's in place. Looks awesome.
patrick
JimTeTe said:Looks Great Patrick ......... I'm thinkin about it, gotta go check them out. Is that one partially curved?
Jim
Hows about a nice set of steer horns :dontknow: :dontknow: :dontknow:Coley 1334 said:yup its curved i just took mine off idk what i am gonna put on there until my billet one comes in :dontknow:
Wifey said:Hows about a nice set of steer horns :dontknow: :dontknow: :dontknow:
frank..attack from inside the grill/hood,if i remember right its attached by means of a dowel/hole type deal.5_0_BAIT said:Okay I am dumb. How in the world did you get the other piece off? I could only get the emblem itself off. COuld not figure out how to remove the piece it was mounted too!
just looked again,its just an indentation...but you can drill into it (from the inside)put maybe a punch in the hole and lightly tap on it to pop it off. or you could drill a hole in the top (its just a plastic flat shield left right?) and the hole would give you some leverage to pry it off.5_0_BAIT said:Sanchoba, thanks. I the entire grille but could not seem to get it. Is there plastic in the way of seeing it?
