Fuse 2 keeps blowing
TEST ACTION APPLICABILITY
1 Ignition on, engine not running.
With the DRBIIIt, read DTCs and record the related Freeze Frame data.
Is the Good Trip Counter displayed and equal to zero?
All
Yes ! Go To 2
No ! Refer to the INTERMITTENT CONDITION Symptom (Diagnostic
Procedure).
Perform POWERTRAIN VERIFICATION TEST VER - 2.
2 Attempt to start the engine.
Did the engine start?
All
Yes ! Go To 3
No ! Go To 4
3 Turn the ignition off.
Remove the ASD Relay from the PDC.
Disconnect the PCM harness connectors.
Measure the resistance of the (K342) ASD Relay Output circuit from the ASD Relay
cavity in the PDC to the PCM harness connector.
Is the resistance below 5.0 ohms?
All
Yes ! Go To 7
No ! Repair the open in the (K342) ASD Relay Output circuit.
403
DRIVEABILITY - GAS
4 Install a substitute relay for the ASD Relay.
Attempt to start the vehicle.
All
Yes ! Replace the ASD Relay.
No ! Go To 5
5 Turn the ignition off.
Using a 12-volt test light, probe the (A14) Fused B+ circuits at the ASD Relay
connector in the PDC.
Does the test light illuminate brightly?
All
Yes ! Go To 6
No ! Repair the open or short to ground in the (A14) Fused B+ circuits.
Inspect the related fuse and repair as necessary.
6 Disconnect the PCM harness connectors.
All
Yes ! Go To 7
7 NOTE: Before continuing, check the PCM harness connector terminals for
corrosion, damage, or terminal push out. Repair as necessary.
Using the schematics as a guide, inspect the wire harness and connectors. Pay
particular attention to all Power and Ground circuits.
If there are no possible causes remaining, view repair.
All
Repair
Replace and program the Powertrain Control Module per Service
Information.
Man I wish in my world diagnostics was handed on a silver platter like this! So easy, as long as you have the tools and can understand all the abbreviations.
How long have you had the HID headlights in there? Did you check the wiring on them? If you are killing a 30AMP fuse that is a dead short.
