Gas Saving Tips
Roz
TIPS ON PUMPING GAS
I don't know what you guys are paying for gasoline.... but here in
California we are paying up to $3.50 per gallon. My line of work is in
petroleum for about 31 years now, so here are some tricks to get more of
your money's worth for every gallon.
At the Kinder Morgan Pipeline where I work in San Jose, CA we deliver about
4 million gallons in a 24-hour period thru the pipeline. One day is diesel
the next day is jet fuel, and gasoline, regular and premium grades. We have
34-storage tanks here with a total capacity of 16,800,000 gallons.
Only buy or fill up your car or truck in the early morning when the ground
temperature is still cold. Remember that all service stations have their
storage tanks buried below ground. The colder the ground the more dense the
gasoline, when it gets warmer gasoline expands, so buying in the afternoon
or in the evening....your gallon is not exactly a gallon. In the petroleum
business, the specific gravity and the temperature of the gasoline, diesel
and jet fuel, ethanol and other petroleum products plays an important role.
A 1-degree rise in temperature is a big deal for this business. But the
service stations do not have temperature compensation at the pumps.
When you're filling up do not squeeze the trigger of the nozzle to a fast
mode. If you look you will see that the trigger has three (3)stages: low,
middle, and high. In slow mode you should be pumping on low speed, thereby
minimizing the vapors that are creat ed while you are pumping. All hoses at
the pump have a vapor return. If you are pumping on the fast rate, some
other liquid that goes to your tank becomes vapor. Those vapors are being
sucked up and back into the underground storage tank so you're
getting less worth for your money.
One of the most important tips is to fill up when your gas tank is HALF FULL
or HALF EMPTY. The reason for this is, the more gas you have in your tank
the less air occupying its empty space. Gasoline evaporates faster than you
can imagine. Gasol ine storage tanks have an internal floating roof. This
roof serves as zero clearance between the gas and the atmosphere, so it
minimizes the evaporation. Unlike service stations, here where I work, every
truck that we load is temperature compensated so that every gallon is
actually the exact amount.
Another reminder, if there is a gasoline truck pumping into the storage
tanks when you stop to buy gas, DO NOT fill up--most likely the gasoline is
being stirred up as the gas is being delivered, and you might pick up some
of the dirt that normally settles on the bottom. Hope this will help you
get the most value for your money.
DO SHARE THESE TIPS WITH OTHERS!
WHERE TO BUY USA GAS, THIS IS VERY IMPORTANT TO KNOW. READ ON
The Saudis are boycotting American goods. We could return the favor by
boycotting their GAS. Just buy from gas companies that don't import their
oil from the Saudis.
These companies import Middle Eastern oil:
Shell........................... 205,742,000 barrels
Chevron/Texaco......... 144,332,000 barrels
Exxon/Mobil............... 130,082,000 barrels
Marathon/Speedway... 117,740,000 barrels
Amoco............................62,231,000 barrels
Here are some large companies that do not import Middle Eastern oil:
Conoco................. .0 barrels
Sinclair..................0 barrels
BP/Phillips.............0 barrels
Hess......................0 barrels
ARC0.....................0 barrels
Sunoco..................0 barrels
All of this information is available from the Department of Energy and each
is required to state where they get their oil and how much they are
importing. But to have an impact, we need to reach literally millions of gas
buyers.
Disclaimer: This was forwarded to me within an email. I figured I would pass this along. If it's true, great. If it's false, great. Emails are not the bible. If this is a repost, great.
Roz, Interesting info, Good post. It is true you learn something new everyday.
TNVIPER said:
Hey Jimi you forgot one tip....always try to take south bound roads so you are going downhill...:dontknow: ;)
And tailgate Semi's as often as possible to reduce drag coefficient. ;)
always drive with the rotation of the earth,,,
I don't have any of these gas stations around here!
Can you tell me what ones up here in Alberta,Canada that do not import from the East?
Very interesting info,simple things people never think about!Thanks for the tips.
I have no clue my friend. I just posted the info within an email I had received. . . :eek:
The only company on that list that doesn't import Saudi oil located around here is Conoco. I believe that oil is from Venezuela.
O thought you were going to say dont go to work! then you could save on your biggest gas expense...lol
Yeah, the money you save doing this you can use to fix your busted windshield and chipped paint from the stones the big truck throws off the tires!
BRILLIANT!!!:idea: :rolleyes::aetsch:
Good post Roz. Citgo is owned by chavez. BP is the only fuel I get. I love it when the one on exit 11 gets in price wars with Walmart!! It puts a couple dollars back in the oh pocket!!
belgiumbarry said:
i'm thinking of growing rapeseed and hobbying a lambic....:p :p :p :p :p :p :D
won't that hurt :dontknow: :dontknow: :dontknow:
This thread is hilarious..............a vipertruck forum and we're talking about how to save gas!!!!!!!!:D :eek: LOL:rock:
No middle eastern oil........and no Chavez oil...............I think Hawaii's oil come from the Indonesia area or something.
patrick
