Got the leaky
madmanadam
NW corner
Just put the Ram in the air and it looks like I have the oil line leak and rear of motor leak.
Are the oil lines kit available?
Not sure where the leak is coming from on the back of motor.
Thanks
Adam
See if stinker has any oil lines --he's the man to ask on those --- The pics are to small to see,,,,
The rear is probably a rear main seal. Migt as well order a clutch to if the stock clutch is still in there. You're gonna have to drop the tranny if it is the rear main seal.
Yeah, and while your at it, you might as well forge the internals, ask Stinky:p :D
pull the little inspection cover and check those 4 rear oil pain bolts. If they are even a smidge loose it will leak like that also. I put loctite on mine when I did my build. those little bastards like to rattle loose some times.
replace oil lines first it could just be oil blowing back there then clean up see if oil still comes back then its seal .my lt1 had timing cover leak it was so bad you would think exhaust pipes were leaking.
Thanks for info,
Just took a look and behind the inspection plate no wet oil, yea. It does look like the oil is from the oil lines. Yes, it is the original clutch. not ready to do the clutch yet, need to baby it a bit more. fund are tight right now and need to save a bit.
