swaped grills with my cuz
Plan on doing the same exact swap tomorrow.....how do you get the tabs out of the grill? Do they just pop out?VIPER said:swaped grills with my cuz
kickinassrt-10 said:Plan on doing the same exact swap tomorrow.....how do you get the tabs out of the grill? Do they just pop out?
so you push them inward or outward? Are they reusable after?VIPER said:no - just use a punch or a small round shaft to knock them out - no need for a drill:rock: :rock: :rock: :rock: :rock: :rock: :rock: :rock: :rock: :rock:
kickinassrt-10 said:so you push them inward or outward? Are they reusable after?
You can only access the rivet pin from one side. Just push it through. Try to keep track of them, they can fly away (ricochet) when you push them through. Yes they are reusable if you have all the pins for the rivets.kickinassrt-10 said:so you push them inward or outward? Are they reusable after?
SilvrSRT10 said:You can only access the rivet pin from one side. Just push it through. Try to keep track of them, they can fly away (ricochet) when you push them through. Yes they are reusable if you have all the pins for the rivets.
SilvrSRT10 said:It's easiest if you remove the whole grille from the truck and set it on towel covered table. Punch or drill the pins through the rivet and swap grilles. Take your time and don't force anything other than the pins.
I have the mini screw driver set...do you push in on the middle piece only or the whole rivet?SPACEMONKEY1 said:I just punched mine out with a hammer and a mini screwdriver, sort of like i chizzled them out. Most people have these mini sets of screw drivers and they fit perfect for this.
like Silvr said, watchout because they will fly out and you might not see where they go. Good luck bro!! :rock: :rock:
Demon 8 said:I want to do this on my silver as well, great work
I just swapped mine out this morning plus made $20 which paid for the paint...Demon 8 said:I want to do this on my silver as well, great work
kickinassrt-10 said:I just swapped mine out this morning plus made $20 which paid for the paint...
It's easy to pop out....I would recommend taking the entire grill assembly out, it makes it a hell of a lot easier..![]()
mauiSRT/10 said:Blacked out grill looks very good on your yellow truck. Good call!!:rock:
